****re-posting as a question. Mistakenly made it a discussion***
I know this has been asked before in several different combinations and permutations over the years
Recently we have migrated from 2016 WGPDM to PDMPro 2020
I would like to create a little macro for my users to help the model and drawing "cleansing/version upgrade" become a little easier
A few points to make:
- I am aware of the File version upgrade tool that could be batch run on the server. However our data is so old and so mixed up in legacy SW versions that running it causes error or failures, have tried on a sample selection of files, did not work.
- #TASK is not a possibility for us in terms of batch processing this, or using their built in macros template switch macro, since they have recently upgraded to a paid tier version, therefore excluding as an option
- My macro skills are novice to none.
- SW API is not an option (my skills there are non-existent)
Intended order of events in macro: On Currently open drawing:
- Saves current file (to convert to latest SW version) - Works
- Deletes all drawing layers. - works
- Brings in specific drafting standard. Drafting standards managed by Vault. Local vault view root varies between client machines (c:\, d:\), ideally should be "drive agnostic" or %root vault view folder% - Not working
- Applies selected drafting standard - Partially working, will work once step 3 is solved
- Applies specific sheet format to all sheets - Partially working, only does it on sheet 1
- Sets auto-zone border to correct layer, on all sheets - Works
- Deletes any existing revision table - Works
- Applies new specific revision table template - Not Working
I have managed to scrape together the below macro using the record function plus bits and bobs from the forum & :&
A lot of things are working great, however, current issues I am having:
Line 51
need to make that cycle through C:...or D:.... see . Maybe with a similar IF not,else statement?
Line 53-54:
Would like the macro to cycle through all sheets automatically and apply the selected sheet format.
I tried recording the "apply to all sheets" button when setting it but it seems to not return the respective code snippet.
Even better if it could incorporate a silent "No" click to the old "do you want to rename blocks" pop-up.
Line 55-60:
I would like to also add the If not statement for this section to check and look for the specific rev table format and then apply it to the sheet.
This would also need to check alternative drive letters similar to Line 51 issue mentioned above. Currently it deletes the existing table but then brings in the SolidWorks default table template rather than bringing in the specific one I want. See also snippet below macro code.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
' Zoom To Fit
Part.ViewZoomtofit2
' Zoom To Fit
Part.ViewZoomtofit2
' Zoom To Fit
Part.ViewZoomtofit2
' Save
Dim swErrors As Long
Dim swWarnings As Long
boolstatus = Part.Save3(1, swErrors, swWarnings)
' Delete all existing Layers start
Dim doc As ModelDoc2
Dim lyrMgr As LayerMgr
Dim v As Variant
Dim i As Integer
Dim count As Integer
Set doc = swApp.ActiveDoc
Set lyrMgr = doc.GetLayerManager
count = lyrMgr.GetCount
v = lyrMgr.GetLayerList
For i = 0 To count - 1
lyrMgr.DeleteLayer (v(i))
Next i
' Delete all existing layers over
boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swEdgesTangentEdgeDisplay, 0)
boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swEdgesTangentEdgeDisplay, 1)
boolstatus = Part.Extension.LoadDraftingStandard("C:\Vault View\VCT Live\zzz Vault Administration zzz\VCT Templates\Drafting Standards\ANSI-Part Drawing-Make.sldstd")
Part.ClearSelection2 True
boolstatus = Part.SetupSheet5("Sheet1", 12, 12, 1, 2, False, "A4-L-ANSI-mm.slddrt", 0.297, 0.21, "Final Part View", True)
boolstatus = Part.Extension.SelectByID2("DetailItem181@Sheet1", "REVISIONTABLE", -8.37584846247418E-02, 0.043120236745548, 0, False, 0, Nothing, 0)
Part.EditDelete
Dim currentSheet As Object
Dim myRevisionTable As Object
Set currentSheet = Part.GetCurrentSheet()
Set myRevisionTable = currentSheet.InsertRevisionTable(True, 0.103008000834168, 0.04, 2, "")
' Zoom To Fit
Part.ViewZoomtofit2
' Zoom To Fit
Part.ViewZoomtofit2
' Zoom To Fit
Part.ViewZoomtofit2
' Set AutoZone Border to "Auto-Border" Layer Start
Set swDoc = swApp.ActiveDoc
Set swDraw = swDoc
vSheetNames = swDraw.GetSheetNames
For k = 0 To swDraw.GetSheetCount - 1
swDraw.ActivateSheet vSheetNames(k)
swDraw.EditTemplate
Set swSketch = swDoc.GetActiveSketch2
swDoc.ClearSelection2 (True)
vSketchSeg = swSketch.GetSketchSegments
vLayName = "Auto-Border"
For i = 0 To UBound(vSketchSeg)
Set swSketchSeg = vSketchSeg(i)
swSketchSeg.Layer = vLayName
Next i
Set swView = swDraw.GetFirstView
vAnn = swView.GetAnnotations
For j = 0 To UBound(vAnn)
Set swAnn = vAnn(j)
swAnn.Layer = vLayNamer
Next j
swDraw.EditSheet
swDoc.ForceRebuild3 True
Next k
' Set AutoZone Border to "Auto-Border" Layer Over
' Save
rev table specific placement macro I have found from
Line 26 would need an IF not, else to look ad Drive letter D: as well
Not sure if all if this is actually needed? shouldn't bringing in the specific rev table template "A4-L-Revision Table.sldrevtbt" apply its specific settings as saved when creating the template file in the first place? (anchor point location and snap, stationary corner, layer setting, revision symbol shape etc etc).
Option Explicit
Dim currentsheet As SldWorks.Sheet
Dim revTableAnno As SldWorks.RevisionTableAnnotation
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set currentsheet = swDraw.GetCurrentSheet
swDraw.ActivateSheet (currentsheet.GetName)
' Insert a revision table
Set revTableAnno = currentsheet.InsertRevisionTable2(True, 0, 0, swBOMConfigurationAnchor_TopRight, "C:\Vault View\VCT Live\zzz Vault Administration zzz\VCT Templates\Revision Table Templates\A4-L-Revision Table.sldrevtbt", swRevisionTable_HexagonSymbol, True)
'boolstatus = swModel.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swRevisionTableSymbolShape, 0, swRevisionTableSymbolShape_e.swRevisionTable_CircleSymbol)
'revTableAnno.AnchorType = swBOMConfigurationAnchor_BottomLeft
