I'm trying to create a macro which will insert a revision table and set the anchor to the bottom left corner.
No matter what I do it inserts the revision table at the anchor on the top right corner. What gives?
Option Explicit
Dim currentsheet As SldWorks.Sheet
Dim revTableAnno As SldWorks.RevisionTableAnnotation
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set currentsheet = swDraw.GetCurrentSheet
swDraw.ActivateSheet (currentsheet.GetName)
' Insert a revision table
Set revTableAnno = currentsheet.InsertRevisionTable2(True, 0, 0, swBOMConfigurationAnchor_BottomLeft, "C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\English\standard revision block.sldrevtbt", swRevisionTable_CircleSymbol, True)
boolstatus = swModel.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swRevisionTableSymbolShape, 0, swRevisionTableSymbolShape_e.swRevisionTable_CircleSymbol)
