I am making this thread in extension to my previous thread here. I am trying to create a custom pipe routing library that will allow me to drag and drop my custom pipe routing components into a route and have the components auto-size to the route.
I am still having trouble with the pipe routing elbows, which also seems to be associated with my custom routing problem. I created a custom elbow with two configurations, one for a .75 in pipe, and another for a 1 in pipe. Then I added it to the pipe routing library through the routing component wizard. I then created a custom route property page, using the standard pipe file as the pipe, and my custom elbow as the elbow. When I went to use this property upon starting a pipe route in an assembly I got the following error:
Following this error, I did some further research on creating my own template, but could not find a solution. When creating a pipe route, elbows are not being automatically inserted at corners. I also noticed that in the Route Properties window of the Routing Library Manager my PVC elbow is classified as a 0 angle, rather than a 90. I am not sure if this is related to the overall issue nor how to manipulate this. Regardless, here is what my route property page looks like:
Any insight on how I can create my own routing library that can use my own elbows and components (and eventually my own pipe) would be greatly appreciated.
it sounds like you have a small problem with configuration naming.
what is wrong with the standard elbows that SolidWorks gave you?
How about doing a save as to you custom folder to an existing elbow that solidworks likes and then deleting all the configs that you do not want to see.
