I am having difficulty with a custom pipe routing elbow. I created the part and set it up through the routing component wizard. When I place the component into an assembly to start a pipe route it works fine, creating pipes at either end of the component, however when I add the component to an already present route it is not added as a component of the route and no pipes are created. How can I fix this?
I have attached a picture of the issue as well.
I'm not a routing expert by any means but you can drag that component into the folder if you want it to be housed there.
