BOM export macro problem
Question asked by MA Thieu on Aug 28, 2015
Hello all!
A friend made me a macro to export a BOM from a drawing in Excel (CSV format). My problem: I need that macro can add a new table for each execution. I can't find how I can do that. For exemple: My drawing have a 3 line BOM. I run the macro once, it works properly.
But I need a new table (same) at the end of the previous if I run again the macro. How can I modify this code????
This is ma actual code:
    Dim swFeat As SldWorks.Feature
    Dim swBomFeat As SldWorks.BomFeature
    'Application SW
    'Document actif
    Set swModel = swApp.ActiveDoc
    Debug.Print "Document : " & swModel.GetTitle
    'Récupération de la première fonction
    Set swFeat = swModel.FirstFeature
    'Parcours des autres fonctions
    Do While Not swFeat Is Nothing
        'Récupération des fonction de type Nomenclature (BOM)
        If "BomFeat" = swFeat.GetTypeName Then
            Debug.Print "Fonction : " & swFeat.Name
            Set swBomFeat = swFeat.GetSpecificFeature2
            'Traitement
            ProcessBomFeature swBomFeat
        Set swFeat = swFeat.GetNextFeature
    Loop
    vTableArr = swBomFeat.GetTableAnnotations
Sub ProcessBomFeature(swBomFeat As SldWorks.BomFeature)
    Dim vTableArr As Variant
    Dim vTable As Variant
    Dim swTable As SldWorks.TableAnnotation
    Dim swAnn As SldWorks.Annotation
    Dim nNumCol As Long
    Dim nNumRow As Long
    Dim sRowStr As String
    Dim i As Long
    Dim j As Long
    'Récupération des tables d'annotation
    'Parcours des tables d'annotation
    For Each vTable In vTableArr
        'Récupération d'une table
        Set swTable = vTable
        'Récupération des contenus
        Set swAnn = swTable.GetAnnotation
        'Nombre de colonne et de ligne
        nNumCol = swTable.ColumnCount
        nNumRow = swTable.RowCount
        'Nom et type de table
        Debug.Print "    Table : " & swAnn.GetName & " Type : " & swTable.Type
        'Parcours des lignes
        For i = 0 To nNumRow - 1
            sRowStr = "      "
            'Parcours des colonnes
            For j = 0 To nNumCol - 1
                sRowStr = sRowStr & swTable.Text(i, j) & " | "
            Next j
        ' Affichage du contenu
        Debug.Print Left(sRowStr, Len(sRowStr) - 1)
        Next i
        'Dossier de sortie
        Dim xlsPath As String
        xlsPath = Mid(swModel.GetPathName, 1, InStrRev(swModel.GetPathName, "\"))
        'Nom du XLS
        Dim xlsName As String
        If InStrRev(swModel.GetTitle, ".") > 0 Then
            xlsName = Mid(swModel.GetTitle, 1, InStrRev(swModel.GetTitle, ".") - 1) & ".csv"
        Else
            xlsName = swModel.GetTitle & ".csv"
        Debug.Print "Sortie : " & xlsPath & xlsName
        'Export Excel
        swTable.SaveAsText xlsPath & xlsName, ";"
    Next vTable
    MsgBox "Export terminé"
Could anyone help me??
