I WANT TO CREATE A FABRICATION DRAWING USING FRACTIONAL DIMENSIONS AND THEN CREATE ANOTHER SHEET FOR MACHINING WITH DECIMAL DIMENSIONS. ANY WAY TO SET THE DOCUMENT SETTINGS FOR INDIVIDUAL SHEETS?
nope - document settings are for the document (hence the name).
you can change the units for any dimensions you want to be different than the document setting in the property tab for the selected dimension(s)
