Hello, I searched and didn't find the answer, but I'm also new to SW and not sure if I'm using the correct terminology.
I have a sketch of a rectangle 49" x 72'".
I created a weldment using 1.25" x .125" Tube following that sketch.
The tube is centered on the sketch but I want the edge of the tube to follow the sketch, When I click on locate profile there are no points on the round tube to
Basically I want the inside dimensions of the Tubular frame to be the same dimensions as the rectangle. Can't figure out how to accomplish this.
Create the weldment then expose the sketch. Edit the sketch and add points. As long as you continue to use that profile in that part the points will remain. I am currently in the process of adding points to all of my weldment sketches just for this issue.
As soon as Deepaks macro stops running I will send a screenshot.
