I have SolidWorks version 2014 SP 2.0 ,I have received some drawings in file type EDRW and I want to open them with SolidWorks and convert them to .dxf or .dwg can this be done?
You can't open up eDrw files in Solidworks. Are you able to get the sender of the eDrw to send it in a different format? You will probably be able to use a file converter software to change it to dwg/dxf but I am not sure if it is foolproof.
Don't look that way
