Hello all. Attached is a file I have been working on. I am trying to combine surfaces and make them a solid object. When I go to the knit command and proceed with the operation I check the box's that say merge and make a solid. The operation completes just fine. But when I try and do a cross section check it still shows the body as being hollow. Any ideas? Thanks in advance for the help.
Hi Frank,
you are missing a few surface faces that stop it being a solid. I have done a surface fill on these just to allow it to form a solid. I have attached the file for you to peruse.
