Why are these variables not setting/updating on my card?
Question asked by Steven Soeder on Aug 26, 2015
Latest reply on Aug 31, 2015 by Steven Soeder
I'm trying to use IEdmEnumeratorVariable5::SetVar to update some file card variables based on user input into a windows form.
The code executes, the file is checked out and checked back in with the appropriate comment in the history; however the variables on the card are not updated.
Here is my code - not sure where the problem is.  Hoping someone can see it!
In efforts to make it as concise as possible, I've commented what some of the variables are.  I have confirmed the data in all of my variables is correct at run-time.
NOTE:  I don't know when this forum introduced this new code recognition feature, but it is awful!!  I could not paste from visual studio to here - it kept trying to interpret things and deleted lines of code, changed expressions, etc.  Very very bad!!  I had to copy everything into notepad and copy/paste from there.  It still kept adding "true" in random inappropriate places wherever I had an "IF" block that had to be deleted, and I lost all formatting so now everything appears blue.  This is the best I could get it to look.  Sorry if it's tough to read.  If you find typos, it's most likely due to editing.  The code does execute - there are no compile errors .
          With ReceivedCommand  'Private Structure.  Contains:  .SourceVault = poCmd.mpoVault; .SourceCommand = poCmd; .SourceSelection = ppoData
                Dim RequestFile As IEdmFile5 = .SourceVault.GetFileFromPath(Path)
                Dim ParentFolder As IEdmFolder6 = .SourceVault.GetFolderFromPath(Left(Path, InStrRev(Path, "\")))
                Dim UnlockLater As Boolean = False
                If Not RequestFile.IsLocked Then
                    UnlockLater = RequestFile.LockFile(ParentFolder.ID, .SourceCommand.mlParentWnd, CInt(EdmLockFlag.EdmLock_Simple))
                Dim CardVariables As IEdmEnumeratorVariable5 = RequestFile.GetEnumeratorVariable
                Dim CardComment As String = String.Empty
                Dim CardBy As String = String.Empty
                Dim CardDate As String = String.Empty
                Dim CardDisposition As String = String.Empty
                Dim Success As Boolean
                'Card variable names.  I've double checked and these are correct.  All tied to "edit box" controls on the file card.
                Const CommentVariable As String = "DispComm"
                Const ByVariable As String = "DisposedBy"
                Const DateVariable As String = "DisposedDate"
                Const DispositionVariable As String = "Disposition"
                'We allow users to re-disposition a request so we want to keep any previous disposition information so it is not lost
                Success = CardVariables.GetVar(DispositionVariable, "@", CardDisposition)
                If Success Then
                    Success = CardVariables.GetVar(CommentVariable, "@", CardComment)
                    If Success then Success = CardVariables.GetVar(ByVariable, "@", CardBy)
                    If Success then Success= CardVariables.GetVar(DateVariable, "@", CardDate)
                    If Success Then CardComment = "Previously dispositioned as: """ & CardDisposition & """ by: " & CardBy & " on: " & CardDate & vbNewLine &
                                                     "---------Previous disposition explanation---------" & vbNewLine & CardComment
                Dim UserManager As IEdmUserMgr5 = .SourceVault
                Dim User As IEdmUser5 = UserManager.GetLoggedInUser
                CardComment = UserComment & CardComment 'UserComment is a String.  Populated from a windows form text box.
                CardDate = Today().ToString("yyMMdd", Globalization.CultureInfo.InvariantCulture)
                CardBy = User.Name
                CardDisposition = UserDisposition 'UserDisposition is a String.  Populated from a windows form text box.
                CardVariables.SetVar(DispositionVariable, "@", CardDisposition)
                CardVariables.SetVar(CommentVariable, "@", CardComment)
                CardVariables.SetVar(ByVariable, "@", CardBy)
                CardVariables.SetVar(DateVariable, "@", CardDate)
                CardVariables.Flush()
                If UnlockLater Then RequestFile.UnlockFile(lParentWnd:= .SourceCommand.mlParentWnd,
                                                            bsComment:="Dispositioned as " & CardDisposition,
                                                            lEdmUnlockFlags:=0)
                .SourceVault.RefreshFolder(ParentFolder.LocalPath)
            End With
