Good Day everyone...
I'm trying to mesh a part that has the hub / female part of a spline shaft. Basically it's a toothed hub. For some reason though, the mesh keeps failing. I've tried practically everything but the mesh keeps failing.
Here is a picture of the part. I've also attached a copy of it as well.
Any help will be greatly appreciated.
Kind Regards,
David
Yes, that is the problem. You can see the gap in the section view below. (gray vertical line to the left).
