Hello I am working on a sheet metal part and I am having trouble with one of my corners. When I try to do a weld corner it works just fine. But I want to limit the welding done on this corner so I applied a closed corner, but after I do that it does not do the welded corner in solidworks. I do need the corner welded so since this is not working could you give me advice on how to get this to work or should I just put the weld in manually since this does not seem to work for me.
Thank you for the advice and help. The picture I sent is of the closed corner that I can not get to weld. I did not attach a picture of the welded corner when it is not closed but it worked so I did not attach a picture of that.
An aside, but with such a narrow form, can your tooling do these flanges without collision?
Cheers,
Kevin
