- With Structural Member I created two vertical beams (89mm x 89mm).
- Than I created a horizontal beam of 19mm x 38mm horizontaly to create the mortises in the vertical beams.
- Deleted the body of the horizontal body
- Created a new horizontal body (Weldment) of 19mm x 38mm.
- Now I wanted to use Trim/Extend to trim the horizontal body and get tenons on both end of the size of the holes (mortises) in the vertical beam.
However if I use Tirm/Extend with bodies the horizontal body is trimmed at the vertical body and if I use Face/plane and select all the faces of the hole Solidworks keeps saying "Rebuild Errors, some of the selected bodies are missing".
What am I doing wrong? Is there a better way to create Mortise and Tenon?
Regards
Bart
Hello Ben,
Welcome to the forum. I've never tried to create a mortise and tenon joint, but I'll be glad to try to help. However, it's difficult to visualize what you have without seeing the model. Can you post your part? Click on the text "Use advanced editor" at top right of the Reply box (I know it doesn't look like a link, but it is), then there will be a link at lower right to attach files.
