JWJason Wilger24/08/2015
I have been trying my hand at routing some air and hydraulic tubes in an assembly. I started with routing thru clips which is quite easy, but routing to a frame member on my assembly I am routing in is quite a task, or so it seems. I have used other routing packages, and this operation is quite simple: just pick the face you want to route to, and the software offsets the spline so that it is tangent and of you go. this isn't the most robust way of doing this type of work, but time always wins, and in my case I must save some. Is there any way of selecting a face in the assembly while laying out the route and have the flexible tubes follow?
