I want to make an influent of geothermal heat of the air tempeature in the haus. I know just a tempertaure of it (+5C). How can I set it in FlowSimulation. Unfortuantly I've found just heatflow Q or q
Hi Alexander,
You will only get Q and q if you apply a surface heat source, try a volume heat source, this should allow you to specify the temperature.
Steve
