Macro to autoname sheets based on Custom Property
Question asked by Steve Mlynczak on Aug 21, 2015
Latest reply on Aug 26, 2015 by John Stoltzfus
I have this code below that works on a single sheet. It grabs the the custom property named "Description" from the inserted model and the sheet size and renames the sheet according to that data The problem is when I add another sheet to the file the macro quits working. Will someone take a look and see what I have messed up. I cant get passed this issue. The problem code I think is highlighted in bold letter below
Dim swSheet As SldWorks.Sheet
Dim swModelview2 As Configuration
Dim ConfigName As String
Dim vSheets As Variant
Dim swView As SldWorks.View
Dim i As Integer
Dim Part As SldWorks.ModelDoc2
Dim Count As String
Dim SheetProperties As Variant
Dim paperSize As swDwgPaperSizes_e
Dim width As Double
Dim height As Double
Dim sheetsize As String
Dim CP As String
Dim resolvedValOut  As String
Dim swCustProp      As CustomPropertyManager
Set swModel = swApp.ActiveDoc
Set swDraw = swApp.ActiveDoc
Set swApp = GetObject("", "SldWorks.Application")
Set Part = swApp.ActiveDoc
vSheets = swModel.GetSheetNames
For i = 1 To swModel.GetSheetCount
swModel.ActivateSheet vSheets(i - 1)
Set swSheet = swModel.GetCurrentSheet
Count = swModel.GetModelViewCount
Set swView = swModel.GetFirstView
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
Set Sheet = swApp.ActiveDoc.GetCurrentSheet
Set swCustProp = swModel.Extension.CustomPropertyManager("")
swCustProp.Get2 "Description", CP, resolvedValOut
'MsgBox CP
'************ Determine Sheet Size *********************
    SheetProperties = swSheet.GetProperties
    paperSize = swSheet.GetSize(width, height)
    If paperSize = 0 Or paperSize = 1 Then
            sheetsize = "a"
        ElseIf paperSize = 2 Then
            sheetsize = "b"
        ElseIf paperSize = 3 Then
            sheetsize = "c"
        ElseIf paperSize = 4 Then
            sheetsize = "d"
        ElseIf paperSize = 5 Then
            sheetsize = "e"
        Else
        sheetsize = "d"
Do While Not swView Is Nothing
ConfigName = swView.ReferencedConfiguration
Loop
swSheet.SetName i & sheetsize & " - " & CP
Next i
