What would be the most efficient way to generate the texture of this emblem? Ive tried using linear feature patterns and linear sketch patterns but it takes ages to rebuild.
Thanks in advance for the help.
Ben
Ben
If you need it actually modeled so you can 3D Print it with a pattern like that long rebuild times are going to happen. On the flip side you could possibly get this texture by doing some adjustments in your printer software and only have to model the deeper cuts. If you're just looking for visual you would just use a appearance texture.
Cheers,
Derek
