I'm wanting to rename some of my variables to make them more understandable for other people to decipher our setup. What effect would it have on the system if any?
All the metadata is stored with reference of variable ID so changing variable name won’t affect anything on card design etc. However as Prasad mentioned, make sure you are not changing anything in the property mapping. Also the variable name by itself doesn’t make any difference to end user - except if they run
help to know the details of variable mapping. What they see on card is variable value.
Hi Mike, it shouldn't have much effect on the data cards. What you would need to do, is make sure that your mapping to SolidWorks custom properties remains the same as it was before.
Prasad
