Hello, I have a problem that I have created a part and there are a couple of angles in it (but nothing too complex). I have made extruded cuts on these angles, once they have been flattened. When I bend them again, they are fine and look all correct, but when I go to flatten the part, the lines get all messed up!!!! Help please.
Part is attached.
Message was edited by: Aaron Diggelmann
Aaron,, I'm not sure why you added another Cut-Extrude after the Flat Pattern. Why did you do that? If you suppress that (or delete it) I believe it flattens correctly.
Seems like you did everything correctly with the exception of the second (Cut-Extrude1)
Give me a clue.
