I've got one Dispatch action that works perfectly between States, Prelim to Authorized.
I am in need of a separate dispatch action that will activate between Baseline and Authorized.
From what I see in Dispatch, Every transition that has the same destination state will use that one Dispatch Action.
So what would be the best way (or a command that will achieve this) to create a dispatch action to only activate after a specific source state (or transition) and before a specific destination state.
SET VARIABLE on each transition, then use JUMP command on DISPATCH to check for these variables and do your actions accordingly.
