I import a lot of customer supplied files in the .STP format. I convert them into a Solidworks format and make drawings. Is there a way to have the "Hole Callout" function supply the QTY of holes as well as the diameter. Currently I manually count the holes then edit the Dimension Text box, which works but depends on my ability to count.
In a drawing you can add a hole table for each face on your model with holes in it. Combine tags and sizes (if you like).
