I have created a drawing template which calls the custom props from the model (custom props are on config tab - only 1 config in the model).
On the first sheet all the fields on the drawing are populated with the correct values. When I add the second sheet some of the fields are left blank while others are populated, any idea why? I don't understand why it works fine on the first sheet but on subsequent sheets some of the properties are blank. I do get the following message when creating new sheets but am not sure how to prevent this. Currently I usually just select No.
In moment you create a new page only the $PRP properties are shown becouse these are properties specific to drawing file.
The $PRPSHEET properties will be shown when you insert the first view in the new page of drawing.
