Macro only works near origin.
Question asked by John Legtenberg on Aug 19, 2015
Latest reply on Aug 19, 2015 by John Legtenberg
I am working on a macro. I want to insert a sketch with my custom properties as text. After that, the sketch has to be renamed to "Gravering". When i click near the origin the name changes correct. If i click further away from the origin the name does not change.  The custom properties are "PARTNO" and "Revisie1". I also want to know if it is possible to check if there already is a sketch with the name "gravering"
Here is my code:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim Point As Variant
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
'Get xyz of seected face edge point etc.
Point = SelMgr.GetSelectionPoint2(1, -1)
'Print xyz
Debug.Print "X= " & Point(0)
Debug.Print "Y= " & Point(1)
Debug.Print "Z= " & Point(2)
'Print result of selecting component
Debug.Print Part.Extension.SelectByID2("", "COMPONENT", Point(0), Point(1), Point(2), False, 0, Nothing, 0)
Part.Extension.SelectByID2 "", "FACE", Point(0), Point(1), Point(2), False, 0, Nothing, 0
Part.SketchManager.InsertSketch True
Part.InsertSketchText Point(0), Point(1), Point(2), "$PRP:""PartNo""+$PRP:""Revisie1""", 0, 0, 0, 100, 100
Part.ClearSelection2 True
Part.ActivateSelectedFeature
Part.Extension.SelectByID2 "", "SKETCH", 0, 0, 0, False, 0, Nothing, 0
Part.SelectedFeatureProperties 0, 0, 0, 0, 0, 0, 0, 1, 0, "Gravering"
Thanks!
