LHLarry Hills18/08/2015
I want to extrude cut (center point arc slot) a solid cylinder. The two end points of the slot are parallel to the axis of the cylinder. If you make the cut AND turn the cylinder around, the cut is upside down. I want the resulting cut look the same orientation on both faces. Any suggestions?
