Hi All,
I had created Drawing Templates, with Sheet Scale 1:1. When I start drawing, my single drawing can result in 5 or more sheets, so I just copy and add templates as more sheets required. But when I start adding views, I see that some of my Sheet Scales are changed automatically for example to 1:75. This puts me into problem, because then I cannot save the sheets properly in .dwg format. All scaling issues comes up and everything goes haywire. Any advice on how to set/fix the sheet scale in SW Drawings so that whenever I save it in .dwg format, the .dwg drawing is saved exactly as it was in SolidWorks Drawing. Thanks in advance.
Regards,
LS
Tools > Options > Drawings and uncheck Automatically scale new drawing views.
