I am trying to run flow simulation for a model pump generator that pumps 300 GPM of water. My main problem is that I cant choose the same face for two boundary conditions, but I can't. I need to specify the outlet flow rate of 300 GPM and also give an environment pressure (since a pressure opening condition needs to present in every simulation). I have also given an inlet velocity of 0.5 ft/s to the surrounding walls that simulate a river.
How else can you define the boundary conditions to get around this problem? I need to specify an outlet volume flow on the outlet face, but where can I specify the pressure opening?
Cabi
You can put the volume flow at the inlet and the environmental pressure at the outlet.
Because water is incompressible the volume flow is constant all over the circuit so you can have a very easy relationship between volume flow and fluid speed at the inlet.
