I think it is odd that If a sketch is missing its sketch plane reference, you need to drill down all the way to edit sketch plane to find that out. I spend a lot of time clicking around - but if there were an icon or some other flag that I could see to tell me that the issue with the feature is the sketch plane, life would be easier...
Is there a good trick, or do we need an ER? Thanks!
-Nate
Hi Nathan,
It should in fact give a warning and if it does not, it may be a bug so you should submit it to your VAR. Here is an image of a simple case I just created by sketching on a face, then rolling back, cutting the face off and then rolling forward.
I hope this helps,
Jim
