I'd like to see the effect on a pair of rotor blades from a flow of air whose pressure oscillates sinusoidally over time.
Is there a way to set up a flow simulation with an oscillating pressure in the fluid and monitor how the blades rotate as a result?
Kind Regards
Charbel
This is not possible, there are two major problems:
1. It is not possible to set a pressure boundary condition that is time dependent
2. It is not possible to simulate dynamic fluid-structure interactions, only rigid solid geometry
