My assembly is a bike, and the one that made this assembly didn't make the wheel, but he took one from the web. My problem is that i don't know how to modify the size of a part of the wheel. Thanks for the help.
If you have it you might want to try "Feature Recognition" in order the turn the wheel into something you can work with.
Edit: Of course I'm assuming the wheel off the web is not a SW part but an imported part.
I think this could be the solution for my problem but when I click on "Feature recognition" it occurs an error that says: " The part contains solids in revolution. FeatureWorks can not proceed". (I have SW in italian so the translation of the error could be a little different). How can I solve this problem? thanks
Hi Nicolo.
In an assembly click on a part and then click 'Edit Part', or edit component on the top ribbon
This opens up the Edit part mode where you can make your changes.
The part to edit remains solid, other parts become transparent.
When you have finished the editing, exit out of this mode by clicking the edit component button again.
This takes you back into the assembly mode
Mark
