I have a macro to traverse each drawing view and change the notes in that view to use the document font.
It works but it changes the fonts in the sheet format/ titleblock as well which I don't want it to do.
Any ideas on where I went wrong?
Option Explicit
' Select all annotations and set to use Document Font - 08/12/15 by Casparia
Dim swView As SldWorks.View
Dim swTextFormat As SldWorks.textFormat
Dim i As Long
Dim j As Long
Dim annotations As Variant
Dim notes As SldWorks.annotation
Dim count As Long
Dim bool As Boolean
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
' Iterate through all the views on the drawing to find annotations
Set swView = swDraw.GetFirstView
Do While Not swView Is Nothing
count = swView.GetAnnotationCount
' Iterate through all the annotations in each drawing view that has them and set to use document font
If count > 0 Then
annotations = swView.GetAnnotations
For j = 0 To UBound(annotations)
Set notes = annotations(j)
bool = notes.SetTextFormat(i, True, swTextFormat)
Next j
Set swView = swView.GetNextView
Loop
