I've a new HP workstation, but SW always hang, and cooling fan speedup run; it's happen 2-3 times per day. sometime display unusual flash.
Anybody can help me?
After run Performance Benchmark Test , Compare others same model, my hardware config are more stronger, but the score is very weak, see below. I've also asked HP tech. support, Done a lot of software diagnostics, but still can't settle the problem. I suspect my AMD graphic card working un-stable:
My PC:
HP ZBook 14 G2 Workstation
Win 7 Pro
8G DDR3 Ram
1st 256 GB PCIe
SSD, and 2nd 256 GB SATA SSD
Integrated with Intel HD 5500 Graphics, and 1 GB AMD FirePro™ M4150
Thks!
Wen Yan
Hi Wen,
What version of SolidWorks are you running on your machine there?
Have you updated your Graphics card driver or at least ensured you are using the certified drivers found here: Graphics Card Drivers | SOLIDWORKS
When you are accessing files are you doing so from your local machine? or are they located on a Network location?
Are you able to repeat the hang is there something in particular you are doing?
Michael
