Does anybody know why my bend might be fused with other bend without me going all the way back through this tutorial and starting over?
Andrew,, The issue you are having is your Cut-Extrude2 is not normal. Check the Normal Cut and that will take care of the problem. The second issue you have is you made this part in inches. Should be mm.
Here is a comparison of Erik's part and yours.
