PV360  swRayTraceRenderOptions.ContourEnabled NOT working from Solidworks 2012 to 2015
Question asked by Sean Fan on Aug 11, 2015
Latest reply on Aug 12, 2015 by Sean Fan
I need to render hundreds of full colour JPG for website as well as contour only images for printed instructions.
so I used this macro which is pretty much a slightly modified version of the official api online example.
I intented to call this fuction a coule of times, and use Contour Options to alter the render result.
the debug line prints parameter as expected, but the parameter has no influence on the render result.
Is this a bug or my mistake?
apreciate your help
Sub swRenderImage(ImageHeight, ImageWidth As Integer, ImageFormat As Integer, ContourOption As Boolean, Suffix As String)
Dim swRayTraceRenderer As SldWorks.RayTraceRenderer
Dim swRayTraceRenderOptions As SldWorks.RayTraceRendererOptions
Dim Errors As Long
Dim Warnings As Long
Dim sfile As String 'dim source file
Dim tfile As String 'dim target file
Dim status As Boolean
'Set swApp = Application.SldWorks
'Set swModel = swApp.ActiveDoc
'OpenDoc6(sfile, swDocPART, swOpenDocOptions_Silent, "", errors, warnings)
' Access PhotoView 360
Set swRayTraceRenderer = swApp.GetRayTraceRenderer(swPhotoView)
' Get and set rendering options
Set swRayTraceRenderOptions = swRayTraceRenderer.RayTraceRendererOptions
'Get current rendering values
Debug.Print "Current rendering values"
Debug.Print "  ImageHeight          = " & swRayTraceRenderOptions.ImageHeight
Debug.Print "  ImageWidth           = " & swRayTraceRenderOptions.ImageWidth
Debug.Print "  ImageFormat          = " & swRayTraceRenderOptions.ImageFormat
Debug.Print "  PreviewRenderQuality = " & swRayTraceRenderOptions.PreviewRenderQuality
Debug.Print "  FinalRenderQuality   = " & swRayTraceRenderOptions.FinalRenderQuality
Debug.Print "  BloomEnabled         = " & swRayTraceRenderOptions.BloomEnabled
Debug.Print "  BloomThreshold       = " & swRayTraceRenderOptions.BloomThreshold
Debug.Print "  BloomRadius          = " & swRayTraceRenderOptions.BloomRadius
Debug.Print "  ContourEnabled       = " & swRayTraceRenderOptions.ContourEnabled
Debug.Print "  ShadedContour        = " & swRayTraceRenderOptions.ShadedContour
Debug.Print "  ContourLineThickness = " & swRayTraceRenderOptions.ContourLineThickness
Debug.Print "  ContourLineColor     = " & swRayTraceRenderOptions.ContourLineColor
Debug.Print " "
' Change rendering values
Debug.Print "New rendering values"
swRayTraceRenderOptions.UseSolidWorksViewAspectRatio = False
swRayTraceRenderOptions.UseSceneBackgroundImageAspectRatio = False
swRayTraceRenderOptions.ImageHeight = ImageHeight
swRayTraceRenderOptions.ImageWidth = ImageWidth
swRayTraceRenderOptions.ImageFormat = ImageFormat
swRayTraceRenderOptions.PreviewRenderQuality = swRenderQuality_Good
swRayTraceRenderOptions.FinalRenderQuality = swRenderQuality_Best
'BloomOption
swRayTraceRenderOptions.BloomEnabled = False
swRayTraceRenderOptions.BloomThreshold = 70
swRayTraceRenderOptions.BloomRadius = 4
'ContourOption ( I think setting contour Options reset Shaded Contour option )
      swRayTraceRenderOptions.ContourEnabled = ContourOption
    ' it seems this is not working in 2012
      swRayTraceRenderOptions.ShadedContour = False
swRayTraceRenderOptions.ContourLineThickness = 5
swRayTraceRenderOptions.ContourLineColor = RGB(0, 0, 0)
' Display the preview window
'status = swRayTraceRenderer.DisplayPreviewWindow
' Close render
'status = swRayTraceRenderer.CloseRayTraceRender
If ContourOption = True Then
' Invoke final render window
 status = swRayTraceRenderer.InvokeFinalRender
' Abort final render window
'status = swRayTraceRenderer.AbortFinalRender
' Render to  format
Dim FSO As FileSystemObject
Set FSO = CreateObject("Scripting.FileSystemObject")
Debug.Print FSO.GetBaseName(sfile)
Debug.Print FSO.GetFileName(sfile)
Debug.Print FSO.GetParentFolderName(sfile)
'Assign a Target File Name
sfile = swModel.GetPathName
tfile = FSO.GetParentFolderName(sfile) & "\" & FSO.GetBaseName(sfile) & Suffix
Debug.Print "Target = " & tfile
status = swRayTraceRenderer.RenderToFile(tfile, 0, 0)
Set swRayTraceRenderOptions = Nothing
' Close render
