Hello all,
This picture is a side profile view of a cradle we are creating. The dashed line (A) would be the hidden lines of a normal shell feature. Solid line (B) is where I would like for the shell to stop. Like a controlled shell feature. Is there a good way to go about doing this? Thanks in advance.
Hi Frank
work within the part rather than the assembly, cut the part but don't save it as separate files (so you have two bodies in the same part), and ensure "consume cut bodies" is unchecked. then apply your shell only to the body you want, then you can use the combine feature to add them together to bring it back to a single body again
what version of solidworks are you running? I can send the above model to show the process if you are using 2015.
