Macro filename manipulation
Question asked by Eghard Kolste on Aug 11, 2015
Hey there,
I am using a macro from my former colleague and this macro creates perfect PDF's, but for the DXF's it adds "00_...." and "01_..." in front of the filename if the file has more than one sheet. I would like to add the sheetname at the back of the filename. Filename is the same as the part number and I want the output file named as "part number_sheet 1.dxf" and so on. How can I manage that with the existing macro?
Thanks in advance!
Eghard
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim sPathName               As String
    Dim nErrors                 As Long
    Dim nWarnings               As Long
    Dim nRetval                 As Long
    Dim bShowMap                As Boolean
    Dim swModelDocExt           As SldWorks.ModelDocExtension
    Dim swExportData            As SldWorks.ExportPdfData
    Dim filename                As String
    Dim boolstatus              As Boolean
    Dim lErrors                 As Long
    Dim lWarnings               As Long
    Dim bRet                    As Boolean
    Set swModel = swApp.ActiveDoc
    ' Strip off SolidWorks drawing file extension (.slddrw)
    ' and add DXF file extension (.dxf)
    sPathName = swModel.GetPathName
    sPathName = Left(sPathName, Len(sPathName) - 6)
    sPathName = sPathName + "dxf"
    ' Show current settings
    ' Turn off showing of map
    bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
    Set swModelDocExt = swModel.Extension
    Set swExportData = swApp.GetExportFileData(swExportPDFData)
    filename = swModel.GetPathName
    filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
    boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
    boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
    If boolstatus Then
        MsgBox "Save as PDF DXF in same directory was successful, Eghard Kolste!" & vbNewLine & filename
    Else
        MsgBox "Save as PDF failed something went wrong, Error code:" & lErrors '
    swApp.SetUserPreferenceToggle swDXFDontShowMap, False
    bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
    If bRet = False Then
        nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
    ' Restore old setting
    swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
