I need a button that generates a DXF of a sheet metal part.
I need it to, upon clicking the button, check to make sure units are IPS (our plasma cutter only recognizes inches). If units are not IPS, they need to be changed to IPS before generating the DXF.
I need it to save the DXF as "DXF - [FILENAME]"
I need it to, once units have been changed to IPS, give me the option to select a face from which to generate the DXF.
I'll apologize in advance. I haven't had the time to look into learning the API or another programming language. I'm just needing this macro to be made.
If I can't get it produced on here, could someone point me in the direction of someone who would write this macro?
