When trying to print a drawing, solidworks 2015 print service is thinking that the drawing is a model. any solutions? see attached jpgs
it doesnt matter what i do, when i try to print, doesnt matter what printer i select, what size print i select, what scale i want it to print too, it prints 1:1 to 8-1/2" x 11"
If the print preview looks OK, but doesn't print correctly, it's most likely to be a printer driver problem.
Can you clarify what you meant by the title, "solidworks 2015 thinks some drawings are models" ?
I don't understand the correlation between the title and only being able to print letter size drawings.
OK, I understand that (thanks Deepak), but that doesn't explain only being able to print 8-1/2 x 11. That is most likely a printer driver issue.
i have uninstalled and reinstalled solidworks 3 times. cleaned the registry 3 times of anything pertaining to solidworks, and removed and reinstalled the printers 3 times. i am thinking that there is something in the registry that is causing this and i cant find it. i can print just fine from any other software, i.e. word, excel, adobe... i am guessing that i am the only one out of the millions of solidworks users that has ever had this problem.
If this just started, have you shut down your computer and re-started it? If that doesn't fix it, then I'm all out of ideas.
