I am trying to cut the shape on the left side of the part to follow the contour/radius. (Red arrow in picture)
A cut sweep is not working and i'm not sure why? Any suggestions?
In order for a Sweep Cut to work the path and profile have to intersect. If you'll zoom way in on yours you'll see that they don't. Edit Sketch5 and make that endpoint coincident with the arc from Sketch3 and it will work.
YAY! Thank you it worked
you path it not touching the profile.
works after touching, use pierce.
