0 Replies Latest reply on Aug 10, 2015 4:08 PM by Paige Reisman
    Iterating with insertrefplane causes Solidworks Crash?
    Paige Reisman
      I'm trying to iterate what (I thought) was a fairly simply process that needs to be repeated 100+ times.
      The general goal is to first, sketch lines between a set of points and the midpoint. Then I need to create a reference plane, coincident to each point and perpendicular to each line.
      Here is the code so far: For the record, before starting the code, I import points using an excel to point cloud macro that I someone else created.
      Dim skSegment As Object
      Dim boolstatus As Boolean
      Dim sketchPointArray As Variant
      Dim pointCount As Integer
      Dim i As Integer
      Dim strSketchName As String
      Set swModel = swApp.ActiveDoc
      'Get 3dsketch with points via SelectByID2
      boolstatus = swModel.Extension.SelectByID2("3DSketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
      swModel.EditSketch
      Set the3Dsketch = swModel.GetActiveSketch2
      swModel.SketchManager.InsertSketch True
      'Get SketchPoints from within '3DSketch with points'
      sketchPointArray = the3Dsketch.GetSketchPoints2
      pointCount = UBound(sketchPointArray)
      'create new 3DSketch to connect the points
      ' For each SketchPoint in the "3DSketch with points"
      'Coords of Midpoint (pt 1)
      x1Value = sketchPointArray(0).X
      y1Value = sketchPointArray(0).Y
      z1Value = sketchPointArray(0).Z
      'Begin Loop
      For i = 1 To pointCount
      swModel.SketchManager.Insert3DSketch True
      'Coords of Point on Head Cap (pt 2)
      x2Value = sketchPointArray(i).X
      y2Value = sketchPointArray(i).Y
      z2Value = sketchPointArray(i).Z
      'And create a line between them
      Set skSegment = swModel.SketchManager.CreateLine(x1Value, y1Value, z1Value, x2Value, y2Value, z2Value)
      swModel.ClearSelection2 True
      Next i
      'Make planes in the same code
      For i = 1 To 2
          strSketchName = "Sketch" & i + 1
          boolstatus = swModel.Extension.SelectByID2("", "EXTSKETCHPOINT", sketchPointArray(i).X, sketchPointArray(i).Y, sketchPointArray(i).Z, False, 0, Nothing, 0)
          boolstatus = swModel.Extension.SelectByID2(strSketchName, "SKETCH", 0, 0, 0, True, 1, Nothing, 1)
          Dim myRefPlane As Object
          Set myRefPlane = swModel.FeatureManager.InsertRefPlane(4, 0, 2, 0, 0, 0)
          Part.ClearSelection2 True
      Next i
      The code works perfectly until the part I bolded - in which the program doesn't give me any error messages nor does it even attempt to make a reference plane, it simply crashes all of solidworks entirely.
      I cut the program down to only act between a few points, and it still crashes.
      Does anyone know what I can do to fix this problem? Is there any other way I can iterate through different points/lines and create several reference planes?
      Paige
