MPMichael Plummer10/08/2015
I'm pretty new to Solidworks, but have a decent amount of experience with other software, so solid modeling's not new to me. I'm having an issue with sketch-driven patterns. Say I'm trying to place several bolts in a flat plate. What I've been doing is:
1) Place one bolt manually
2) Create a sketch on plate surface with a point at the center of each hole
3) In sketch-driven pattern, select the sketch, select a point near the first bolt (with "selected point") and then select the bolt.
The problem with this is that it duplicates the first bolt, placing one inside the manually-positioned one. Using "Instances to skip" doesn't work, as I can't select the same instance as the selected point in step 3. Any way to fix this? Thanks.
