Hello, I would like to know if there is anyway to customize a part template, to show in the BOM the configuration name every single time instead of showing the part name (I know I can do this manually but I want to avoid doing that for every single configuration or every single file)
I had never thought about it, but I just opened a new part, went to the Default configuration's Properties and changed the BOM Option to Configuration Name, as shown below. I then saved the Part Template and closed the file. I started a new Part with this Part Template and it still showed Configuration Name, so the change stuck. If you add additional configurations you'll still need to make that change, but at least it should take care of the first one.
