As shown above, three posts on the right is patterned version of the left one.
The post is consisted of a cylindrical weldment structural member, and a block as pin top, which is extruded right on top of the post body.
We want the total length of the post, including the pin top, to be displayed as cutlist length automatically.
The result is interesting, the one on the very left worked just as we expected, however the ones on the right, which is patterned body, shows a wrong length. How can this be? it is exact pattern of the body, how can they have different length in Cutlist?
I also attached the part file so please kindly take a look and suggest some solution. This bug occurs in the 2015 sp4 as well.
I would treat this as a bug. It should be same for all bodies. Also they should be under same cut list and not different. Though there is a way out to get the correct length in this scenario just checked and found that the method is not working in this case.
