Hello i am now starting to use sw sheetmetal, and am wondering whether i really need to worry about k factors.
we use ali, mild steel, 430 & 441 stainless nothing any thicker than 1.2mm is the metal really going to grow enough to worry about k factors????
we do not anything that is that accuracy critical.
any help would be appreciated
thank you
In a word. Yes. Depending on what your application is depends on how critical the accuracy of the bend calculation. We were using k-factors and found that k-factors not matter how good our calculation was inaccurate for us, we have since set up gauge tables for our different processes. I have set up one for Aluminium usage as well as our galvanized sheet. As a sign company it's important for us to have pieces that fit with low tolerance so to have a cleaner finish but if you are bending a pan around a frame you need it to be accurate.
