How to access a created property manager features?
Question asked by Danny Bradford on Aug 5, 2015
Latest reply on Aug 6, 2015 by Danny Bradford
Greetings all,
I have created a property manager that has 2 selection boxes and a button. The selection boxes are limited to only edges and single selections each selection box.
My work is in VB.net.
FYI that combo box PIN 1 and PIN 2 is just there for a future use and does not participate with the code in question.
I have played extensively with variations of the following within the "Add Pins" Button subroutine:
        Dim swApp As SldWorks
        Dim swModel As ModelDoc2
        Dim swSelMgr As SelectionMgr
        Dim swFeat As Feature
        Dim the_edge As Edge
        Dim instance As IModelDocExtension
        Dim Append As Boolean = False
        Dim Mark As Integer = 0
        Dim Callout As Callout = Nothing
        Dim SelectOption As Integer = 0
        Dim value As Boolean
            swApp = GetObject("", "SldWorks.Application")
            swModel = swApp.ActiveDoc
            swSelMgr = swModel.SelectionManager
            instance = swModel.Extension
            pm_Selection.SetSelectionFocus()
            pm_Selection.SetSelectedItem(0, True)
            'Dim test As Integer = pm_Selection.SelectionIndex(0)
            swFeat = CType(pm_Selection.GetSelectedItems(0), Feature)
            value = swFeat.Select2(False, 0)
            MsgBox(value)
            pm_Selection.GetSelectedItems()
            swFeat = swSelMgr.GetSelectedObject6(0, -1)
            MsgBox(swFeat.GetID.ToString)
Please dont read too much in the code as it has changed a million times and I am not sure if what you see above even works in its current state.
I have tried to utilize the property manager selection boxes to select the edges in Solidworks and then grabbing them there but I am at a complete loss.
Simply put, how do I programmatically utilize each of the items in the selection boxes to perform other functions like measuring them, create planes, points etc?
Your help is greatly appreciated!
Danny B
