Has anyone figured out in the registry or in any settings file how to disable this awful notification when borrowing a network license. Solidworks takes awhile to boot on some machines especially after upgrading for 2014 to 2015 the FastStart fixes seem to be negated by the new improvements... Solidworks however will not load until a user intervenes and clicks "OK"... why? The program should know I want it to load considering I ran the executable in the first place - why would they ask again if its ok to load.
Bottom line if you've figured out how to disable this notification thru some sort of registry fix or file modification please share as I've approached my VAR (Hawkridge) and they approached solidworks and said this new "improvement" is intended functionality and that there is no fix.
Rob
This message is annoying. It is not a useful function. At best it should only warn you when it is getting close to expiring! SW please give us a way to disable this!
