I want to create a macro to select X plane from a selected parts in an assembly. can anybody help me? Still new in programming skill.
Thank you.
Thank you.
Option Explicit Const ReqPlane As Long = 3 Dim swApp As SldWorks.SldWorks Dim Part As SldWorks.ModelDoc2 Dim boolstatus As Boolean Dim longstatus As Long, longwarnings As Long Sub main() Dim swSelMgr As SldWorks.SelectionMgr Dim swComp As SldWorks.Component2 Dim swCompModel As SldWorks.ModelDoc2 Dim swFeat As SldWorks.Feature Dim swCorrFeature As SldWorks.Feature Dim PlaneCount As Long Dim bRet As Boolean Set swApp = Application.SldWorks Set Part = swApp.ActiveDoc Set swSelMgr = Part.SelectionManager If swSelMgr.GetSelectedObjectCount2(-1) = 0 Then Exit Sub Select Case swSelMgr.GetSelectedObjectType3(1, -1) Case swSelCOMPONENTS Set swComp = swSelMgr.GetSelectedObject6(1, -1) Case Else Set swComp = swSelMgr.GetSelectedObjectsComponent4(1, -1) End Select If swComp Is Nothing Then Exit Sub Set swCompModel = swComp.GetModelDoc2 Set swFeat = swCompModel.FirstFeature Do While Not swFeat Is Nothing If "RefPlane" = swFeat.GetTypeName Then PlaneCount = PlaneCount + 1 If ReqPlane = PlaneCount Then Set swCorrFeature = swComp.GetCorresponding(swFeat) If swCorrFeature Is Nothing Then Exit Sub bRet = swCorrFeature.Select2(False, 0) Exit Do End If End If Set swFeat = swFeat.GetNextFeature Loop End Sub
Dim swSelMgr As ISelectionMgr
Dim swSelGroup As New Collection
Dim swFeat As Feature
Set swModel = swApp.ActiveDoc
For i = 1 To swSelMgr.GetSelectedObjectCount
swSelGroup.Add swSelMgr.GetSelectedObjectsComponent3(i, -1)
Next i
swModel.ClearSelection2 True
For j = 1 To swSelGroup.Count
Set swComp = swSelGroup.Item(j)
Set swFeat = swComp.FeatureByName("X Plane")
val = swFeat.Select(True)
Next j
Dont completely know what you were looking for but that selects the "X Plane" of every selected component. Does not leave the components selected though. If you wanted both the components and their plane selected you just have to delete "swModel.ClearSelection2 True"
Next i
Next j
