I have noticed that the file gets the Configuration specific property "Revision" during the EPDM action of incrementing revision, and I can not figure out why this is happening. The variable "Revision" has these settings (they are default that comes with an installation):
According to the manual:
2014 SOLIDWORKS Enterprise PDM Help - Variable Mapping - SOLIDWORKS Files
CustomProperty block should only be written to the Custom property area of solidowks file. But "Revision" field is also created in "Configuration specific" area in solidworks file, though you can see that SWCfgProperty is not present in the attributes list. So why is it created, and how to stop that?
It is not a problem, but just out of curiosity it would be interesting to figure it out.
Thank you for your advice
How do you have the transition configuration defined? If you leave the configuration field blank, it will update all.
Updates only the @ configuration.
