2 Replies Latest reply on Aug 3, 2015 9:57 AM by Yong Ning
    Why only use Traverse Feature in Drawing.don't use GetSelectedObject5?
    Yong Ning
      Why don't use SwSelMgr.GetSelectedObject5(1) → Result is Error
         Dim SwFeat as Feature
         Set SwFeat = SwSelMgr.GetSelectedObject5(1)→Result is Error.
      dim SwSheet As Sheet
         Set SwSheet = SwSelMgr.GetSelectedObject5(1)→Result is True.
      Code is
         Dim SwSelMgr As SelectionMgr
            Set SwSelMgr = SwModel.SelectionManager
         Dim SwFeat As Feature, SwSheet As Sheet
            Debug.Print SwSheet.GetName
      Why Select Feature in Sheet of Drawing. can be use Traverse Feature.
      code is
      Private Sub l5()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
            Set SwApp = Application.SldWorks
            Set SwModel = SwApp.ActiveDoc
            SwModel.ClearSelection2 True
            'Stop
            Set SwFeat = SwModel.FirstFeature
            Do While Not SwFeat Is Nothing
                If SwFeat.GetTypeName = "DrSheet" Then
                    Debug.Print SwFeat.Name, SwFeat.GetTypeName
                    SwFeat.Select True
                Set SwFeat = SwFeat.GetNextFeature
            Loop
