I need to copy a single line 350 times but each time the x dimension/coordinate will be different. Anyone know how this could be done?
See attached part. I used the variable pattern limited functionality in conjunction to a crazy workaround.
I am really frustrated by how limited is the variable pattern in 2015. You cannot pattern even surface features!!! That being said, in the attached part, you can change the X1, X2, Y1, Y2 dimensions and see your patterned lines updated.
Update 1: I have modified the file, by using the Intersection Curve. Thus, you can add or remove rows in the table and the patterned line sketch will update as expected.
Update 2: If you are under subscription, you will want to use SW 2016 to work with this file. Cannot tell you why in this forum, but you will see the advantage right away!
The sketch linear pattern doesn't allow for varying instances. However that is most likely a process that could be done using a macro.
