Shouldn't a rectangular relief have been added to edge-flange3 as it is currently modeled in the attachment? SW 2015 SP4.
Thanks.
Thanks.
Martin thanks for the reply. But my question is shouldn't the software have put a rectangular relief here? It looks like a tear. I have auto-relief selected under the sheet-metal feature. If I select custom relief under the edge-flange3 feature nothing changes unless I alter the sketch.
This is what I was expecting to happen:
I'm not sure why nothing changes on your end. Let me work on that to see if I can duplicate what you are experiencing. I added an edit to my first response. your ratio will have to be something less than 1
Thanks Dennis. I originally used .5 as the ratio and then tried increasing after it failed. See the fan plug bkt posted below for the first time I saw this happen. I didn't notice until working on the part for a while.
Nice,, I think that was clever the way you set up the edge flanges. It looks as though, in this case, that the edge flange has no choice but not to add a relief since it is on the edge of the tab which protrudes out from the adjacent edges. I think in this case I would add the reliefs in the "Sketch13" sketch or with a new cut extrude.
I am trying to avoid having to create a separate cut to accomodate bend reliefs as I thought that was the purpose of auto-relief.
Although, I agree with your statement that the material needs cleared out in that corner. It looks incorrect without using a corner relief as Martin and you have suggested.
BTW, I sent the fan bracket to my VAR and they agreed it should have added rect relief but they couldn't fix it either.
Thanks for the help and excellent alternative methods.
Yes, but I can't get an auto-relief unless I edit the bend sketch. Auto-relief is set to 1 in sheet-Metal and also in the edge-flange. I just get the tear that is shown in the original post.
Roger,,, This sheds a whole different light on your issue. I thought you needed the .06 gap for some reason. Edit the flange sketch and bring the line back down to the radius flange tangent point. Edit the edge flange and check "Trim side bends. Then you will end up with what Bernie has.
Sorry to keep flogging this but I appreciate you guys helping.
I can get the corner relief if I check trim side bends. But the auto-relief is not required to get the corner both of you have posted if trim side bends is checked. I turned off the auto-relief in the sheet metal feature and in the edge-flange and the corner relief looks the same if using trim side bends.
Where I am really expecting the auto-relief to work is on the original fan bracket I posted above. I expected rectangular reliefs next to each flange. The reason for the bottom_tab_cut sketch is to create multiple edges for different flanges, auto-relief would insert rectangular reliefs instead of a tear.
Hi Roger,
In this case I would use Corner relief to achieve a better condition.
